I have two sites (home and farm) connected using Tailscale. Each site has a couple of Win 10/11 PC’s and several devices that cannot use Tailscale so I have a Brume at each site operating as a Subnet Router.
Home has residential FTTP, farm has 5G cellular on a TP-Link NE210 Outdoor router. The 5G router is set in a Bridge mode and has local ip 192.168.254.1. If it is relevant I am in the UK.
It’s a simple setup, Home uses 192.168.3.0/24 for the Tailnet and Farm uses 192.168.50.0/24. The Blume is the gateway at each site. The devices on each site can all communicate over Tailscale VPN without any problem or issues.
The problem is at the Farm site the devices loose connectivity to the Internet at least once per day for a continuous period of several hours. It only affects PC’s which as a result have no internet access even if I turn on the Tailscale app on the PC (I usually don’t have it turned on and just use the Subnet Router. The strange thing is the Tailscale VPN between Home and Farm stays connected and Home and Farm devices can access each other so the Cellular Internet service is up. Internet connectivity will return eventually or if I restart the Farm Blume it will return. If I check on he Tailscale web console the Farm Blume shows Not Connected even though the Tailscale VPN is up,amd working
If I connect to one of the Win PC’s at Farm and try to browse to a website I get Webpage Not Found / DNS error. Command line ping to a known site like www.cisco.com returns host not found and ping 8.8.8.8 returns no response. Normally both test would work without problem.
Browsing from a Farm PC to the 5G router web interface on 192.168.254.1 which is connected via the Brume WAN interface also fails. This would normally be accessible if there was internet access from the Farm LAN.
I am thinking this is a routing problem on the Brume but no idea of the cause. Or it might be. Tailscale problem, I am a bit stuck. Any help or ideas please?
Also the problem only affects Farm and not Home. Blume devices were purchased this week and running latest version.
Thanks in advance.
