Internet Kill Switch and Tor
I have Internet Kill Switch disabled but Tor is blocking IP traffic anyway until Tor is 100% loaded
For example : if Tor is still loading I won't get IP traffic through the non-Tor IP address.
This is perfect with me but it's not the normal Tor behavior.
Just checking if the Mudi Tor rc script does some kind of routing table magic like the Kill Switch already (other than the one in the Mudi web config)?
I only need a confirmation if this behavior is deliberate.
Tor in GL firmware may be processed according to VPN logic.
When Tor is enabled, connecting, disconnected for some reason, re-connecting, the KillSwitch takes effect to ensure that the IP will not be leaked.
Yeah but it acts like Kill Switch Enabled during connecting even when Kill Switch is Disabled.
Is this normal behavior?
The VPN kill-switch is not related to Tor.
When Tor is connecting or cannot be connected (Tor enabled), the client devices will not be able to connect to the Internet.
