I would like to have a wlan that requires a username and password to access.
But I only find access where only a password is needed for wifi.
Can someone help me?
I think you would need to setup a radius server to be able to do this.
Which model are you using for? You can upgrade to v3.0 firmware, which supports EAP.
I use the model GL-MT300N-V2 and installed firmware version is gl-mt300n-v2-3.012.bin.
Does my router support EAP and where can I set it?
Unfortunately. GL-MT300N-V2 is the only model that does not support EAP. Other models support: AR750, AR750S, AR300M, AR150 etc.
