panpan
We will release the new product Spitz Plus (GL-X2000) during CES 2025 Las Vegas. If you want to learn more about this product, please explore the product page and subscribe to the email notifications: Spitz Plus (GL-X2000) | 4G Dual SIM Gateway | Wi-Fi 6 LTE Router - GL.iNet
To become one of our beta testers, make sure you also sign up here: Beta Testing Program - GL.iNet
Do you know if this will support SIM wan aggregation and whether it will be powered by USB -C ?
panpan
3
It will not be powered by USB-C but standard 12V DC input. I think it will support SIM WAN aggregation via our AstroWarp service.
openwrt version of this device?
Summer
5
Spitz Plus (GL-X2000), with the main chip IPQ5018, and the qsdk corresponds to OpenWrt 19.07.
Signed up! I have the spitz and it's great.
slesar
7
Pretty cool. Will be test in UK and test between 2 routers.
Been waiting for an upgrade for a while… Will pricing be closer to that of spitz compared to spitz ax?
DienoX
9
@panpan What price can we expect when this device is released?
Someone asked this before, but I would like to expand on it.
Why wouldn't you want to use USB-C in your mobile device? There are plenty of cheap and convenient power banks and chargers offering USB-C with voltage levels of 12V and 20V that would be able to power this device at 3A.
What's also cool is that plugs are standardized and you don't need to have one special power supply. USB-C adapters are not a great solution either. Regardless, it's going to be a really cool device, I can't wait to get it if it's priced right.
Signed up for beta tester! I already have Puli AX, and I love it, I hope this will be close to it!
Will this new Spitx Plus have eSim capability?
misuzu
12
May I know what modem will it use? Is it Quectel EM06 or something similar? Thanks! Signed up with the test also.
lawnand
13
On thier website it says EM12
misuzu
14
I see. I thought it was Cat6, makes sense. EM12 is a good choice too
lawnand
15
Signed up for beta testing
Wondering if it will be gigabit ethernet instead of fast ethernet on spitz
Also will it be a wifi 6 or wifi 5 router?
hecatae
16
It's wifi6.
Signed up as well to compare against my ZTE mc888
panpan
17
The modules are EG120K-NA and EG120K-EA. We just updated the module info on the product page.
hecatae
18
LTE-FDD: B1/3/5/7/8/20/28/32(optional);
LTE-TDD: B38/40/41/42(optional)/43(optional);
Up to 3 × CA: Intra-band and Inter-band;
WCDMA: B1/3/5/8
LTE-FDD: Max. 600 Mbps (DL)/Max. 150 Mbps(UL);
LTE-TDD: Max. 430 Mbps (DL)/Max. 90 Mbps (UL)
Thank you for confirming LTE Band 32 on the EA version
Summer
19
It is Gigabit ports, WiFi 6 AX3000
LupusE
20
At first I was very concerned about the lack of USB-C at the Spitz AX (X3000), too. But after installing it in my RV, I think the regular around 12V is a good alternative to the more complex USB-C.
For traveling without RV, there is no difference between the Power Supplies. I would not attach a 3A device to my laptop.
For reference: Spitz AX - Install in a RV
I hope the Spitz Plus will be a great budget alternative, like the Slate Plus to the Slate AX.
