Ioctl errors
I’m getting a ton of these:
user.debug : Function:GetWirelessMacTable Line:667 ioctl → RTPRIV_IOCTL_GET_MAC_TABLE_STRUCT fail!
Any Idea how to fix this?
Here's the output of the oc-release file:
cat /etc/os-release
NAME="OpenWrt"
VERSION="18.06.1"
ID="openwrt"
ID_LIKE="lede openwrt"
PRETTY_NAME="OpenWrt 18.06.1"
VERSION_ID="18.06.1"
HOME_URL="http://openwrt.org/"
BUG_URL="http://bugs.openwrt.org/"
SUPPORT_URL="http://forum.lede-project.org/"
BUILD_ID="r7258-5eb055306f"
LEDE_BOARD="ramips/mt76x8"
LEDE_ARCH="mipsel_24kc"
LEDE_TAINTS=""
LEDE_DEVICE_MANUFACTURER="OpenWrt"
LEDE_DEVICE_MANUFACTURER_URL="http://openwrt.org/"
LEDE_DEVICE_PRODUCT="Generic"
LEDE_DEVICE_REVISION="v0"
LEDE_RELEASE="OpenWrt 18.06.1 r7258-5eb055306f"
Did you use GL firmware? Or it is built by yourself?
If you mt300n-v2’s firmware, what’s the firmware version are you using?
