Hello, I have found only one way on iOS to have working ad blocker from AdGuard working at the same time with other VPN. I am using Surfshark.
In Surfshark settings we need to change connection type to IKEv2.
Also we need change in iOS AdGuard advanced settings tunnelling mode to “split tunnel”.
In AdGuard app turn on safari extension.
In iOS Safari settings turn on all AdGuard extensions.
In this way we get:
Hydra IP from Surfshark
Ads blocker active all the time when browsing
It doesn’t work on Chrome at all .
As we know android / IOS allows only one VPN connection active so have fully working AdGuard with third party VPN is not possible.
Also AdGuard have their own VPN which work with AdGuard at the same time . I am thinking what solution, protocol they use ??
If anybody know better solution please share your knowledge. Thanks
