iOS DNS issue (MUDI - GL-E750)
When I get connected to any of 2.4GHz or 5GHz WiFi network with an iOS device I get next warning: “Privacy Warning - This network is blocking encrypted DNS traffic”, I was trying different WiFi security settings, but all the same. How to unblock this traffic?
Maybe your carrier network is blocking encrypted dns.
I’m also experiencing this on the GL-MT3000. I’ve tried resetting the iPhone, the router but I never get this message when connected to our main router which is a Google Nest router.
Most likely wifi encryption problem. Can you use WPA3?
I turned on WPA3-SAE and reconnected my iPhone and I’m still getting that same warning. Also, my Google Nest router is using WPA2 so…
Wouldn’t „override DNS“ used by AGH cause blocking encrypted DNS to 3rd party?
I am not sure. But I saw such message several years ago due to use of weak encryption.
I just ran into this message and found that rebooting the IOS device solved the problem. I was getting the privacy warning on my iphone and not on my ipad. Rebooted iphone and problem solved.
