I’m wondering if someone can help me please? I’ve updated my iPhone XS to iOS 14 and now tethering itself will not work. I can connect via USB and have my internet connection shared, on the Router Dashboard it shows as being connected and working but when I go to use the internet there is no connection. It just hangs on the page, this is since the latest update.
I’ve made sure the Router Firmware is up to date as is the iPhone but I’ve now become stuck. Could someone please help me?
Not workingwith iOS 14 devices (tested various devices, beta1-beta3, tethering starts and iPhone address 172.20.10.1 can be pinged, but traffic stops there and is not routed)[wiki editor: something is messed up with your router configuration then. Pls get it working and return to let us know!]
Never bought an Apple product in my life, so can’t comment about. May be worth posting on the OpenWRT forums? . Android works fine
Yea, same here. iPhone XS Max on IOS 14.0.1. Tethering does not work on my GL-X750 but does work if plugged directly into my SP. Tried lots of things including different cables, resetting the iPhone & the router…
I‘m using the router now in repeater mode to pick up the iPhone‘s hotspot WLAN. But the drops after some time e. g. over night and does not reconnect automatically.
Has anybody an idea how this could be optimized and the disconnect can be avoided? Maybe this is a workaround. But not working properly at the moment.
Yes, it’s not straight forward. But if the repeater mode connected to the hotspot, it works pretty well, speed is ok. Unfortunately it disconnects after a while and does not reconnect automatically. Only after I disable/enable the hotspot on the iphone and connect the router manually again. If this could be fixed and the connection would be stable 24/7, it would be fine.
This is very clear and NOT the issue. Everything is correctly configured on the iPhone side and the iPhone is connected via USB. But the router is not tethering the iPhone‘s internet connection. Have a look here:
As a workaround of the USB tethering issue, I put my router in ‚repeat‘ mode to pick up the iPhones wifi hotspot. This works, but without constant traffic the router drops the wifi tethering connection after a short time.
Now I made the following observation: if I keep a constant traffic on the wifi tethering to the iPhone, the tethering connection (router mode is ‚repeater‘) does not drop but keeps alive. Eg if I‘m constantly streaming music on a device connected to the router, the tethering connection is stable now already for almost 24h. Unfortunately this causes a lot of unnecessary data volume which makes this approach not practical.
Has someone an idea, if there is an option that the router is sending frequently a small data package as a heartbeat via the tethering connection? A ping to an internet server, something like this? This could keep the wifi tethering connection alive without causing too much traffic and data volume. Any idea? I think this could be a workaround.
