IoT in Flint 3 beta firmware 4.9 missing when in AP Mode
Been testing firmware 4.9 on my main Flint 3 router, and was exciting about the new dedicated IoT network settings new to this firmware version, but then I just realized that those options are not present on my other Flint 3 that is configured in AP mode, with is on the other end of the house connected via ethernet to the main Flint 3.
Being a large house I really need the 2 Flint 3’s working to propagate Wi-fi signal everywhere and the optimal solution was to connect them this way.
All my Wi-fi bands as configured the same on both Flint’s except the channels are different to facilitate rooming and avoid signal conflict, I was about to replicate the IoT specific wi-fi setting on the AP mode Flint but sadly the option to do so is not there, even though it’s on the same firmware version.
I understand that being in AP mode, major settings are just not there since it is just working as a “slave” but for this particular scenario I need the option to replicate the Wi-fi settings on the AP mode router or this all think becomes useless to me since the signal from the main router does not reach the other half on my home where several other IoT devices are present.
Is this something to be on the cards for next releases?
I Guess this will only be possible when IoT and Guest networks are implemented using network VLANs rather than bridges. Really hope for this, because it really defeats the purpose to have so many features but then not being able to use them.
I wonder how will this be implemented for scenarios where 1 wifi device for IoT cover is not enough? Surely most medium to large homes will enter this category.
Can devs say a word please? Thank you
You can enable through Luci
Unfortunately, in AP mode the router can only repeat the network it is currently connected to. This is typically the main network of the upstream router, rather than/without Guest or IoT networks.
At present, if you need Guest or IoT support in AP mode, VLAN configuration is still required.
We plan to introduce Mesh functionality for the BE9300 in a future release. At that time, satellite nodes will automatically extend all SSIDs enabled on the main node, including Guest and IoT networks.
(This is still under development, and there is currently no specific release version or timeline available to share.)
