Set up Router https://192.168.8.1 is not working. Is there another IP address that I can use to set up my Beryl travel router?
Be sure you are accessing the router on the LAN side: either the LAN (not WAN) port or wireless.
Have a look at the more comprehensive documentation found here and have a look at the video here to see if that assists.
Make sure to use http://192.168.8.1, not https.
