Hello All,
New to the GL.iNet family of routers, safe to say new to OpenWRT post the LDE merge. I think 12x was the last time I used OpenWrt a lot!
My question is, does IP6 work on GL.iNet firmware on the MT300N?
I have purchased a few MT300N-V2 running 3.102, for a lab project I want to do involving IP6. Hardware wise these are great pieces of kit for the price. Alas though, IP6 is disabled on them as far as I can see (glipv6.enabled=0, and no odhcp startup script, althugh odhcpd does exist in the firmware). So I popped over to OpenWrt, and upgraded to vanilla openwrt 19.07.
IP6 was here, but Wireless was “very” unstable with it turned on. Even with it turned off, 100Mbps for a minute or so killed the Wireless. I can tell after upgrade, that Wireless driver is different.
I wanted to check before enabling IP6.
Thanks for your help
Simon
