After brand new usb A to USB c cable bought today:
Wed Jan 8 18:29:28 2025 kern.info kernel: [12540.861225] usb 1-1.3: new high-speed USB device number 7 using xhci-mtk
Wed Jan 8 18:29:28 2025 kern.info kernel: [12540.980716] ipheth 1-1.3:4.2: Apple iPhone USB Ethernet device attached
Wed Jan 8 18:29:28 2025 daemon.err usbmuxd[9847]: [18:29:28.911][3] Connecting to new device on location 0x10007 as ID 3
Wed Jan 8 18:29:28 2025 daemon.err usbmuxd[9847]: [18:29:28.912][3] Connected to v2.0 device 3 on location 0x10007 with serial number 00008120-000618322172201E
Wed Jan 8 18:29:30 2025 user.warn : skip line without '=' Default
Wed Jan 8 18:32:37 2025 kern.err kernel: [12729.269397] 7981@C11L1,rtmp_chk_rx_err() 5376: CM Length Error
Wed Jan 8 18:32:37 2025 kern.err kernel: [12729.269397] , WlanIndex = 3
Wed Jan 8 18:32:37 2025 kern.err kernel: [12729.278012] 7981@C11L1,header_packet_process() 7261: header_packet_process(): CheckRxError!
Wed Jan 8 18:33:32 2025 daemon.notice netifd: Interface 'tethering' is enabled
Wed Jan 8 18:33:33 2025 daemon.notice netifd: Network device 'eth2' link is up
Wed Jan 8 18:33:33 2025 daemon.notice netifd: Interface 'tethering' has link connectivity
Wed Jan 8 18:33:33 2025 daemon.notice netifd: Interface 'tethering' is setting up now
Wed Jan 8 18:33:33 2025 kern.info kernel: [12785.167697] IPv6: ADDRCONF(NETDEV_CHANGE): eth2: link becomes ready
Wed Jan 8 18:33:33 2025 daemon.notice netifd: tethering (756): udhcpc: started, v1.33.2
Wed Jan 8 18:33:33 2025 daemon.notice netifd: tethering (756): udhcpc: sending discover
Wed Jan 8 18:33:33 2025 daemon.notice netifd: tethering (756): udhcpc: sending select for 172.20.10.10
Wed Jan 8 18:33:33 2025 daemon.notice netifd: tethering (756): udhcpc: lease of 172.20.10.10 obtained, lease time 3600
Wed Jan 8 18:33:33 2025 daemon.info avahi-daemon[4673]: Joining mDNS multicast group on interface eth2.IPv4 with address 172.20.10.10.
Wed Jan 8 18:33:33 2025 daemon.info avahi-daemon[4673]: New relevant interface eth2.IPv4 for mDNS.
Wed Jan 8 18:33:33 2025 daemon.info avahi-daemon[4673]: Registering new address record for 172.20.10.10 on eth2.IPv4.
Wed Jan 8 18:33:33 2025 daemon.notice netifd: Interface 'tethering' is now up
Wed Jan 8 18:33:33 2025 daemon.info dnsmasq[4803]: reading /tmp/resolv.conf.d/resolv.conf.auto
Wed Jan 8 18:33:33 2025 daemon.info dnsmasq[4803]: using only locally-known addresses for domain test
Wed Jan 8 18:33:33 2025 daemon.info dnsmasq[4803]: using only locally-known addresses for domain onion
Wed Jan 8 18:33:33 2025 daemon.info dnsmasq[4803]: using only locally-known addresses for domain localhost
Wed Jan 8 18:33:33 2025 daemon.info dnsmasq[4803]: using only locally-known addresses for domain invalid
Wed Jan 8 18:33:33 2025 daemon.info dnsmasq[4803]: using only locally-known addresses for domain bind
Wed Jan 8 18:33:33 2025 daemon.info dnsmasq[4803]: using only locally-known addresses for domain lan
Wed Jan 8 18:33:33 2025 daemon.info dnsmasq[4803]: using nameserver 172.20.10.1#53
Wed Jan 8 18:33:33 2025 daemon.info dnsmasq[4803]: using nameserver 192.0.0.30#53
Wed Jan 8 18:33:33 2025 user.notice mwan3[772]: Execute ifup event on interface tethering (eth2)
Wed Jan 8 18:33:33 2025 user.notice mwan3[772]: Starting tracker on interface tethering (eth2)
Wed Jan 8 18:33:34 2025 daemon.info avahi-daemon[4673]: Joining mDNS multicast group on interface eth2.IPv6 with address fe80::84d3:28ff:fe7c:bc78.
Wed Jan 8 18:33:34 2025 daemon.info avahi-daemon[4673]: New relevant interface eth2.IPv6 for mDNS.
Wed Jan 8 18:33:34 2025 daemon.info avahi-daemon[4673]: Registering new address record for fe80::84d3:28ff:fe7c:bc78 on eth2.*.
Wed Jan 8 18:33:36 2025 user.info mwan3rtmon[8727]: Detect rtchange event.
Wed Jan 8 18:33:37 2025 user.notice firewall: Reloading firewall due to ifup of tethering (eth2)
Wed Jan 8 18:33:44 2025 daemon.notice netifd: modem_0001_4 (28652): udhcpc: received SIGTERM
Wed Jan 8 18:33:44 2025 daemon.notice netifd: modem_0001_4 (28652): udhcpc: unicasting a release of 192.0.0.2 to 192.0.0.1
Wed Jan 8 18:33:44 2025 daemon.notice netifd: modem_0001_4 (28652): udhcpc: sending release
Wed Jan 8 18:33:44 2025 daemon.notice netifd: modem_0001_4 (28652): udhcpc: entering released state
Wed Jan 8 18:33:44 2025 daemon.notice netifd: modem_0001_4 (28652): Command failed: Permission denied
Wed Jan 8 18:33:44 2025 daemon.notice netifd: Interface 'modem_0001_4' is now down
Wed Jan 8 18:33:44 2025 daemon.notice netifd: Network alias '' link is down
Wed Jan 8 18:33:44 2025 daemon.notice netifd: Interface 'modem_0001_4' has link connectivity loss
Wed Jan 8 18:33:44 2025 daemon.notice netifd: Interface 'modem_0001_4' is disabled
Wed Jan 8 18:33:44 2025 daemon.info dnsmasq[4803]: reading /tmp/resolv.conf.d/resolv.conf.auto
Wed Jan 8 18:33:44 2025 daemon.info dnsmasq[4803]: using only locally-known addresses for domain test
Wed Jan 8 18:33:44 2025 daemon.info dnsmasq[4803]: using only locally-known addresses for domain onion
Wed Jan 8 18:33:44 2025 daemon.info dnsmasq[4803]: using only locally-known addresses for domain localhost
Wed Jan 8 18:33:44 2025 daemon.info dnsmasq[4803]: using only locally-known addresses for domain invalid
Wed Jan 8 18:33:44 2025 daemon.info dnsmasq[4803]: using only locally-known addresses for domain bind
Wed Jan 8 18:33:44 2025 daemon.info dnsmasq[4803]: using only locally-known addresses for domain lan
Wed Jan 8 18:33:44 2025 daemon.info dnsmasq[4803]: using nameserver 172.20.10.1#53
Wed Jan 8 18:33:44 2025 daemon.notice netifd: Network device 'rmnet_mhi0' link is down
Wed Jan 8 18:33:44 2025 kern.info kernel: [12796.957186] net rmnet_mhi0: link_state 0x1 -> 0x0
Wed Jan 8 18:33:45 2025 daemon.notice netifd: modem_0001 (28018): [01-08_16:06:44:215] requestRegistrationState2 MCC: 505, MNC: 1, PS: Attached, DataCap: 5G_NSA
Wed Jan 8 18:33:45 2025 daemon.notice netifd: modem_0001 (28018): [01-08_16:06:44:597] requestRegistrationState2 MCC: 505, MNC: 1, PS: Attached, DataCap: 5G_NSA
Wed Jan 8 18:33:45 2025 daemon.notice netifd: modem_0001 (28018): [01-08_16:06:51:518] requestRegistrationState2 MCC: 505, MNC: 1, PS: Attached, DataCap: 5G_NSA
Wed Jan 8 18:33:45 2025 daemon.notice netifd: modem_0001 (28018): [01-08_16:06:51:897] requestRegistrationState2 MCC: 505, MNC: 1, PS: Attached, DataCap: 5G_NSA
Wed Jan 8 18:33:45 2025 daemon.notice netifd: modem_0001 (28018): [01-08_16:29:22:998] requestRegistrationState2 MCC: 505, MNC: 1, PS: Attached, DataCap: 5G_NSA
Wed Jan 8 18:33:45 2025 daemon.notice netifd: modem_0001 (28018): [01-08_17:03:18:804] requestRegistrationState2 MCC: 505, MNC: 1, PS: Attached, DataCap: 5G_NSA
Wed Jan 8 18:33:45 2025 daemon.notice netifd: modem_0001 (28018): [01-08_17:03:21:026] requestRegistrationState2 MCC: 505, MNC: 1, PS: Attached, DataCap: 5G_NSA
Wed Jan 8 18:33:45 2025 daemon.notice netifd: modem_0001 (28018): [01-08_18:01:51:858] requestRegistrationState2 MCC: 505, MNC: 1, PS: Attached, DataCap: 5G_NSA
Wed Jan 8 18:33:45 2025 daemon.notice netifd: modem_0001 (28018): [01-08_18:33:44:961] requestDeactivateDefaultPDP WdsConnectionIPv4Handle
Wed Jan 8 18:33:45 2025 daemon.notice netifd: modem_0001 (28018): [01-08_18:33:44:967] requestDeactivateDefaultPDP WdsConnectionIPv6Handle
Wed Jan 8 18:33:45 2025 daemon.notice netifd: modem_0001 (28018): [01-08_18:33:45:001] QmiWwanThread exit
Wed Jan 8 18:33:45 2025 daemon.notice netifd: modem_0001 (28018): [01-08_18:33:45:002] qmi_main exit
Wed Jan 8 18:33:45 2025 daemon.notice netifd: Interface 'modem_0001' is now down
Wed Jan 8 18:33:45 2025 user.notice mwan3[2203]: Execute ifdown event on interface modem_0001 (unknown)
Wed Jan 8 18:33:45 2025 user.info mwan3track[28409]: Detect ifdown event on interface modem_0001 (rmnet_mhi0)
Wed Jan 8 18:33:45 2025 user.notice mwan3track[28409]: Interface modem_0001 (rmnet_mhi0) is offline
Wed Jan 8 18:33:45 2025 user.notice firewall: Reloading firewall due to ifdown of modem_0001 ()
Wed Jan 8 18:37:13 2025 kern.err kernel: [13005.162179] ipheth 1-1.3:4.2: ipheth_rcvbulk_callback: urb status: -75
Wed Jan 8 18:37:19 2025 kern.err kernel: [13011.730107] 7981@C13L1,tx_free_v3_notify_handler() 3530: ContTxFailCntTotal = 1, ContTxFailCnt300ms = 1
Wed Jan 8 18:37:19 2025 kern.err kernel: [13011.739504] 7981@C13L1,tx_free_v3_notify_handler() 3533: token used by current wcid = 23, free_token_cnt = 2303
Wed Jan 8 18:37:41 2025 kern.warn kernel: [13033.122431] 7981@C08L2,ap_peer_disassoc_action() 3645: ASSOC - 1 receive DIS-ASSOC request
Wed Jan 8 18:37:41 2025 kern.warn kernel: [13033.130796] 7981@C01L2,wifi_sys_disconn_act() 1002: wdev_idx=2
Wed Jan 8 18:37:41 2025 kern.notice kernel: [13033.138653] 7981@C08L3,hw_ctrl_flow_v2_disconnt_act() 172: wdev_idx=2
Wed Jan 8 18:37:41 2025 kern.warn kernel: [13033.145699] 7981@C13L2,MacTableDeleteEntry() 1938: Del Sta:8e:d2:e2:c8:9c:2d
Wed Jan 8 18:37:41 2025 kern.debug kernel: [13033.542467] entrytb_aid_aquire(): found non-occupied aid:4, allocated from:4
Wed Jan 8 18:37:41 2025 kern.warn kernel: [13033.549527] 7981@C13L2,MacTableInsertEntry() 1577: New Sta:8e:d2:e2:c8:9c:2d
Wed Jan 8 18:37:41 2025 kern.notice kernel: [13033.558591] 7981@C08L3,ap_cmm_peer_assoc_req_action() 1714: Recv Assoc from STA - 8e:d2:e2:c8:9c:2d
Wed Jan 8 18:37:41 2025 kern.notice kernel: [13033.567923] 7981@C08L3,ap_cmm_peer_assoc_req_action() 2241: ASSOC Send ASSOC response (Status=0)...
Wed Jan 8 18:37:41 2025 kern.notice kernel: [13033.577032] 7981@C01L3,wifi_sys_conn_act() 1115: wdev idx = 2
Wed Jan 8 18:37:41 2025 kern.notice kernel: [13033.583066] 7981@C08L3,hw_ctrl_flow_v2_connt_act() 215: wdev_idx=2
Wed Jan 8 18:37:41 2025 kern.notice kernel: [13033.718641] 7981@C15L3,WPABuildPairMsg1() 5310: <=== send Msg1 of 4-way
Wed Jan 8 18:37:41 2025 kern.notice kernel: [13033.725263] 7981@C15L3,PeerPairMsg2Action() 6303: ===>Receive msg 2
Wed Jan 8 18:37:41 2025 kern.notice kernel: [13033.732029] 7981@C15L3,WPABuildPairMsg3() 5595: <=== send Msg3 of 4-way
Wed Jan 8 18:37:41 2025 kern.notice kernel: [13033.738656] 7981@C15L3,PeerPairMsg4Action() 6734: ===>Receive msg 4
Wed Jan 8 18:37:41 2025 kern.warn kernel: [13033.750171] 7981@C15L2,PeerPairMsg4Action() 7098: AP SETKEYS DONE(rax0) - AKMMap=WPA2PSK, PairwiseCipher=AES, GroupCipher=AES, wcid=1 from 8e:d2:e2:c8:9c:2d
Wed Jan 8 18:37:41 2025 daemon.info dnsmasq-dhcp[4803]: DHCPREQUEST(br-lan) 192.168.8.241 8e:d2:e2:c8:9c:2d
Wed Jan 8 18:37:41 2025 daemon.info dnsmasq-dhcp[4803]: DHCPACK(br-lan) 192.168.8.241 8e:d2:e2:c8:9c:2d iPhone
Wed Jan 8 18:37:49 2025 user.notice mwan3[17587]: Execute ifdown event on interface tethering (eth2)
Wed Jan 8 18:37:50 2025 user.notice firewall: Reloading firewall due to ifdown of tethering (eth2)
Wed Jan 8 18:37:50 2025 user.info mwan3track[1163]: Detect ifdown event on interface tethering (eth2)
Wed Jan 8 18:37:55 2025 user.notice mwan3track[1163]: Interface tethering (eth2) is offline
