I'm in a need for iptables-mod-nfqueue which is available for Flint 2 (mt6000) and Brume2. For some reason it's missing from Slate AX.
Is it possible to add in manually (sideload?) or in next releases of the firmware?
Model: GL-AXT1800
Firmware: 4.6.2 & 4.6.4
opkg sources for Slate AX (4.6.4) without said package:
- glinet_core - https://fw.gl-inet.com/releases/v21.02-SNAPSHOT/kmod-4.2.1/arm_cortex-a7/ip60xx
- glinet_gli_pub - https://fw.gl-inet.com/releases/v21.02-SNAPSHOT/packages-4.1/arm_cortex-a7/glinet
- opnwrt_packages - https://fw.gl-inet.com/releases/v21.02-SNAPSHOT/packages-4.0/arm_cortex-a7/packages
opkg sources for Flint 2 (4.6.2) with said package:
- glinet_core - https://fw.gl-inet.com/releases/mt798x/kmod-4.5.7/aarch64_cortex-a53/mediatek/mt7986
- glinet_gli_pub - https://fw.gl-inet.com/releases/mt798x/packages-4.5/aarch64_cortex-a53/glinet
- glinet_gli_packages - https://fw.gl-inet.com/releases/mt798x/packages-4.5/aarch64_cortex-a53/packages
I see drastically different wersion of _packages. It might be the reason.
