M.B
August 25, 2024, 5:25am
I have a question for you guys because i am not that good at iptables. I want to have this concept on my network :
all client to use wg vpn just some devices to be excluded because are work devices and is better to use them with real ISP IP.
i want to use the Killswitch but if i active it now will kill the internet for the devices who are not using VPN(work ones)
is not possible to exclude this work devices out of this rules?
xize11
August 25, 2024, 6:41am
2
is this not possible with vpn policies?
Else if you need something very custom you can edit this piece of code, which is in /usr/bin/route_policy
or you may can also make it much easier by typing ip rule
and check the fw marks, then apply fw marks of wan and test?
admon
August 25, 2024, 6:59am
3
Yup, the VPN policies are the answer to this.
VPN Killswitch is always active - no need to set the additional one.
M.B
August 25, 2024, 8:28am
4
Thanks for info. i will try this way. will take a look on the rules
