For example looking at firmware update found there are two different firmwares: Nand and Nor. Which one is more suitable for what I am trying to do, that is connecting to a special IPv6 server even if my Internet Service Provider only allows IPv4?
I’m not an expert in this, but it seems to me if your first point of connection (your ISP) only supports IPv4, then there is no way to establish Ipv6 downstream?
I am not an expert either, but it seems they developed sort of workarounds for the transition period generally called 6to4 and described for example here 6to4 - Wikipedia. The obvious way to use these workarounds is to have them deployed in a router. OpenWRT already did the work described in the link of my first post and particularly implemented in IPv6-in-IPv4 tunnels (6rd, 6to4, 6in4) but to have it fully functional something should be installed in my GLI mini router since this is obviously not the standard installation.
So I would need some direction to understand what is the more suitable firmware for that and possibly also which software among those mentioned in that link. Well if somebody has some ideas or better experience than me.
@alzhao many thanks for your help and kind attention,
I updated the firmware to 2.25 using the UI and the default automatic system. At the bottom of the UI there is written “Model ar300m NAND”. So it seems ok.
Then tried to install the package “6in4” as required by the tunnel administrator , but got a kernel related error whose snapshot is enclosed
I also tried to connect with SSH, tried:
opkg update
opkg install 6in4
but got the same error
satisfy_dependencies_for: Cannot satisfy the following dependencies for 6in4:
I also tried to upgrade to testing firmware, but got this error:
openwrt-ar300m-2.254.bin successfully uploaded
Version unknow
MD5 b0098be1e33ef36820b40214b540dfa1
Verification result Error: Firmware is not for this hardware.
What should I do now? I have seen another similar thread where you suggested to install this GL.iNet download center Is this updated? Also there is only a tar, with no .bin file inside. Which is the proper way to install it?
I found that even the tar can be used to upload firmware. So tried to upgrade to testing but the installation of 6in4 did not work.
Finally installed this firmware GL.iNet download center and was able to install 6in4 after opkg update via SSH
I would suggest suggest to add to firmware index a few words to explain what is the use of the particular firmware. For example “to install packages via opkg” or “openvpn ready” or whatever. I spent a couple days trying to find out that and was lucky, but many people will give up.
Firmware GL.iNet download center gives me authentication problems with Luci. I mean it authenticates and takes me to “status” but after that when I try to go to network interfaces it takes me again to the login page. I tried to reboot various times. Well a couple of times I got to the network interface page, but was taken to the login page immediately after. It is too much instable to be usable.
Is there any other firmware without this authentication problem and that will let me install packages on my Ar300m?
Ok, I reinstalled the clean firmware WITHOUT reserving the settings. Now no more authentication problems :-))
However I cannot connect with WAN cable, When i click on interface/connect, it tries, but cannot connect. I even tried to change cable. When I plug the same cable into my old router (also with openWRT) it works and I get internet access.
So I wonder what may be the problem since I just made a clean reinstall and touched nothing, just default settings.
If nobody replies I understand there is no solution :-((
On some other thread I have seen that in same cases you suggest to compile it together with the program that you wan to to install, in this case 6in4. Would that be a solution to my problem of connecting with WAN network cable and getting a IP address?
If yes, is it complicated to do? Are there instructions somewhere?
