Hi everyone,
I'm facing an IPv6 issue on my Beryl AX router running firmware 4.6.2. I'm using MullvadVPN directly on the router with IPv6 NAT6 enabled. I've set up a VPN policy based on VLANs: Main network with VPN ON and Guest network with VPN OFF.
The problem is:
- Main Network: Works as expected with both IPv4 and IPv6.
- Guest Network: Gets the correct IPv4 from the ISP but acquires an IPv6 from the VPN instead of the ISP. If I disable the VPN, the Guest network gets the correct IPv6 from the ISP.
Has anyone encountered a similar issue? Any suggestions on how to resolve this?
Thanks in advance for your help!
