Hello, I have a problem configuring the IPv6 relay on my MT6000.
I’m sending a link to someone who has the same problem as me, can anyone help me?
the following error always appears in the log.
I have IPv6 with /64 prefix
I’ve already tried native but after a while the connection becomes slow, pages stop loading and the nat6 option I think would be the worst of all than the ipv6 option and not having nat…
odhcpd[1605]: Failed to send to 240e:xxx%wan@pppoe-wan (Bad file descriptor)
opened 06:40AM - 23 Dec 22 UTC
bug
### Describe the bug
## Device Version:
OpenWrt 22.03.2
odhcpd-ipv6only… 2022-03-22-860ca900-1
odhcp6c 2022-08-05-7d21e8d8-18
## Description
After pppoe reconnection, the IPv6-PD prefix is no longer issued, only a /64 address is issued at `pppoe-wan`, and none of the LAN devices have IPv6 addresses.
After trying with the relay method (see config file below), I can get the address assigned, but the OpenWrt log keeps reporting errors and the LAN devices cannot access any ipv6 site.
Syslog:
odhcpd[1605]: setsockopt(PACKET_ADD_MEMBERSHIP): Invalid argument
`/etc/config/dhcp`
config dhcp 'lan'
option interface 'lan'
option start '100'
option limit '150'
option leasetime '12h'
option dhcpv4 'server'
option ra 'relay'
option ndp 'relay'
option dhcpv6 'relay'
config dhcp 'wan'
option interface 'wan'
option ignore '1'
option master '1'
option ra 'relay'
option ndp 'relay'
## Temporary Solution
I ping6 the router on a LAN device and I can access v6 sites.
To Solve the problem automatically I added script
#!/bin/sh
[ "$1" = "pppoe-wan" ] || exit 0
ip -6 route add default dev br-lan table 6
ip -6 rule add iif $1 lookup 6
Is this a bug of odhcpd-ipv6only?
## VLAN
I set up my `pppoe-wan` interface on an VLAN device `wan.2`. I don't know if VLAN will affect odhcpd.
`/etc/config/network`
config interface 'wan'
option proto 'pppoe'
option ipv6 'auto'
option username 'xxx'
option password 'xxx'
option device 'wan.2'
option ip6assign '64'
config device
option type '8021q'
option ifname 'wan'
option vid '2'
option name 'wan.2'
Chinese Ver. https://www.v2ex.com/t/903292
### OpenWrt version
r19803-9a599fee93
### OpenWrt target/subtarget
ramips/mt7621
### Device
Newifi-D2
### Image kind
Official downloaded image
### Steps to reproduce
_No response_
### Actual behaviour
_No response_
### Expected behaviour
_No response_
### Additional info
_No response_
### Diffconfig
_No response_
### Terms
- [X] I am reporting an issue for OpenWrt, not an unsupported fork.
