Bought this router to have for VPN connection, my service, IPVanish were really rude on customer support saying that it's GL Net's problem that I can't get their service working
I have updated to 4.7.0 Release 7, and I have tried the following;
Uploaded a trimmed version of config.zip to the Open VPN Settings (just keeps retrying, error seems to be unable to resolve host:[ipvanish server] in the log)
Tried signing into WireGuard (error: get third part token fail)
Tried uploading WireGuard zip (just hangs, no log or anything just doesn't connect)
I can connect through the client apps on my devices while connected to the router too
Most likely it's a DNS issue. What DNS settings are you using, do you use adguardhome?
The ipvanish server may be blocked by DNS server, check by issue command in the router terminal.
