Hello all.
I have a sub to IPVanish. I want to configure my AXT1800 to use IPV.
I downloaded one of the IPV config files for US-NewYork and the ca.ipvanish.com.crt file.
I open the VPN Dashboard and under Global Proxy, click Setup Now for OpenVPN.
I click Add Manually in the OpenVPN Client window.
New Provider name IPVanish and click the checkbox.
I rename the ca.ipvanish.com.crt file to ca.ipvanish.com.txt and I get a message upload was successful in the check box but a Failed at the bottom. Additionally I cannot hit Apply to apply the cert.
When I drag and drop the ovpn file I get that the upload is successful but and error that the certificate file is missing (which makes sense) and to please add a cert before continuing.
Can someone point me to the correct procedure to do this please?
Thanks in advance.
