Hi.
I have a GL-MT300N-V2 with the latest firmware (3.025).
Is it possible to use my existing IP Vanish account to set up OpenVPN on this router? If so, where would I get the config from?
Many thanks.
Rich
Hi.
Many thanks.
Rich
Hi.
I don’t see IP Vanish in that list. Is there another I could use in its place?
Thank you.
Rich
Get the ovpn and certs etc from IPvanish and zip it, upload to the router.
Pls refer to this post AR300m openvpn problem - #7 by alzhao
Google and you can find https://www.ipvanish.com/software/configs/
Download the configs.zip and upload directly.
