Hi there,
I am trying to setup a cloud captive portal solution with local coovachilli running on GL-AR300M. Cloud portal I am testing with is ironwifi. Ironwifi has generated config and script files as attached, saying to run the script and claim that it “should work”…
At the moment I’ve got the GL-AR300M working well with my desirable firewall rules. Currently all subnets, lan/wan zones and interfaces are as per default the way factory has shipped it. I am worried by running this script provided by ironwifi it will break what’s been working. For a start, I see that they’ve assumed certain IP subnets and interfaces that seem incorrect to me.
Can someone help look through these scripts and config file to confirm they are ok to go? scripts and configs are below.
Failing above, what is my alternative - another way to enable a simple straight forward captive portal on GL-AR300M?
Thank you
Script file: (PS: where it says URL were originally actual URLs, masked)
#!/bin/sh /etc/rc.common
- init script for chilli -
START=60
STOP=90
NAME=chilli
RUN_D=/var/run
CMDSOCK=$RUN_D/$NAME.sock
PIDFILE=$RUN_D/$NAME.pid
option_cb() { [ -n “$2” ] && echo “HS_$(echo $1|tr ‘a-z’ ‘A-Z’)="$2"” | sed ‘s/$/\$/g’; }
config_load hotspot > /etc/chilli/config
. /etc/chilli/functions
start() {
case ${hs_type:-$HS_TYPE} in
facebook)
HS_PROVIDER=Coova
HS_UAMSERVER=“URL”
HS_UAMHOMEPAGE=“URL”
HS_UAMFORMAT=“URL”
HS_UAMSERVICE=“URL”
HS_UAMDOMAINS=${HS_UAMDOMAINS:+“$HS_UAMDOMAINS,.URL”}
HS_UAMDOMAINS=${HS_UAMDOMAINS:-“.URLt”}
HS_RADIUS=“URL”
HS_RADIUS2=“URL”
HS_RADAUTH=“1812”
HS_RADACCT=“1813”
HS_RADCONF=“off”
HS_UAMSECRET=
internal)
HS_PROVIDER=Coova
HS_USELOCALUSERS=“on”
HS_MACAUTHMODE=“local”
HS_UAMSERVER=“URL”
HS_UAMSERVER=$HS_UAMLISTEN
HS_UAMHOMEPAGE="http://\$HS_UAMLISTEN:\$HS_UAMPORT/www/coova.html"
HS_RADCONF="off"
HS_LOCAL="on"
HS_UAMUIPORT=3442
(grep -v $HS_UAMSERVER /etc/hosts; echo “$HS_UAMLISTEN $HS_UAMSERVER”)>/tmp/hosts
grep $HS_UAMSERVER /tmp/hosts >/dev/null && mv /tmp/hosts /etc/hosts
case ${hs_reg_proto:-$HS_REG_PROTO} in
http) HS_LOCAL_PROTO="http"; HS_LOCAL_PORT="3442" ;;
*) HS_LOCAL_PROTO="https"; HS_LOCAL_PORT="3443" ;;
esac
case ${hs_reg_mode:-$HS_REG_MODE} in
tos) page="tos" ;;
*) page="login" ;;
esac
HS_UAMFORMAT="$HS_LOCAL_PROTO://\$HS_UAMSERVER:$HS_LOCAL_PORT/www/$page.chi"
*chilli*)
echo "Not running hotspot"
exit
esac
HS_SSID=$(wl status|grep ‘^SSID:’|awk ‘{print $2}’|sed s/"//g)
HS_NASMAC=$(grep perm_etheraddr /proc/net/wl0|awk ‘{print toupper($2)}’|sed s/:/-/g|head -n1)
HS_WANIF=$(nvram get wan_ifname)
HS_NASIP=${HS_WANIF:+$(ifconfig $HS_WANIF 2>/dev/null|grep ‘inet addr’|awk -F: ‘{print $2}’|awk ‘{print $1}’)}
HS_DNS_DOMAIN=${HS_DNS_DOMAIN:-cap.coova.org}
HS_DNS1=${HS_DNS1:-$HS_UAMLISTEN}
HS_DNS2=${HS_DNS2:-$HS_NASIP}
HS_NASID=${HS_NASID:-$HS_NASMAC}
HS_MACAUTHMODE=${HS_MACAUTHMODE:-local}
HS_USELOCALUSERS=${HS_USELOCALUSERS:-off}
HS_PROXY_TYPE=${HS_PROXY_TYPE:-none}
HS_RADCONF_URL=${HS_RADCONF_URL:-URL}
HS_CFRAME_URL=${HS_CFRAME_URL:-URL}
HS_CFRAME_SZ=${HS_CFRAME_SZ:-100}
HS_DEFSESSIONTIMEOUT=${HS_DEFSESSIONTIMEOUT:-0}
HS_DEFIDLETIMEOUT=${HS_DEFIDLETIMEOUT:-0}
HS_DEFINTERIMINTERVAL=${HS_DEFINTERIMINTERVAL:-300}
HS_LAN_ACCESS=${HS_LAN_ACCESS:-deny}
HS_CFRAME_POS=${HS_CFRAME_POS:-top}
HS_PROVIDER=${HS_PROVIDER:-Coova}
HS_PROVIDER_LINK=${HS_PROVIDER_LINK:-URL}
HS_LOC_NAME=${HS_LOC_NAME:-My HotSpot}
HS_LOC_NETWORK=${HS_LOC_NETWORK:-Coova}
HS_OPENIDAUTH=${HS_OPENIDAUTH:-off}
HS_ANYIP=${HS_ANYIP:-off}
[ -z "$HS_LANIF" ] && {
[ -e /tmp/device.hotspot ] && {
stop
HS_LANIF=$(wlanconfig ath create wlandev wifi0 wlanmode ap)
for i in 0 1 2 3 4; do ifconfig ath$i mtu 1500; done 2>/dev/null
echo $HS_LANIF > /tmp/device.hotspot
iptables -t nat -A POSTROUTING -o eth0 -j MASQUERADE
iwconfig $HS_LANIF essid ${HS_SSID:-Coova} 2>/dev/null
writeconfig
radiusconfig
(crontab -l 2>&- | grep -v $0
echo “*/10 * * * * $0 checkrunning”
test ${HS_ADMINTERVAL:-0} -gt 0 && echo “*/$HS_ADMINTERVAL * * * * $0 radconfig”
test ${HS_CHECKARP:-0} -gt 0 && echo “*/$HS_CHECKARP * * * * $0 arping”
) | crontab - 2>&-
[ -d $RUN_D ] || mkdir -p $RUN_D
/sbin/insmod tun >&- 2>&-
/usr/sbin/chilli
stop() {
[ -f $PIDFILE ] && kill $(cat $PIDFILE)
crontab -l 2>&- | grep -v $0 | crontab -
rm -f $PIDFILE $LKFILE $CMDSOCK 2>/dev/null
iptables -t nat -D POSTROUTING -o eth0 -j MASQUERADE
wlanconfig $(cat /tmp/device.hotspot) destroy
rm /tmp/device.hotspot
Config file:
HS_WANIF=eth1 # WAN Interface toward the Internet
HS_LANIF=wlan0 # Subscriber Interface for client devices
HS_NETWORK=192.168.15.0 # HotSpot Network (must include HS_UAMLISTEN)
HS_NETMASK=255.255.255.0 # HotSpot Network Netmask
HS_UAMLISTEN=192.168.15.1 # HotSpot IP Address (on subscriber network)
HS_UAMPORT=3990 # HotSpot UAM Port (on subscriber network)
HS_UAMUIPORT=4990 # HotSpot UAM “UI” Port (on subscriber network, for embedded portal)
HS_DNS1=8.8.8.8
HS_DNS2=8.8.4.4
HS_NASID=nas01
HS_RADIUS=35.197.133.220
HS_RADIUS2=35.197.133.220
HS_RADSECRET=“pVPNyw5M9HEYYYToXiI3” # Set to be your RADIUS shared secret
HS_RADAUTH=7227
HS_RADACCT=7228
HS_UAMALLOW=URL
HS_UAMSECRET=“pVPNyw5M9EYUYToXiI3” # Set to be your UAM secret
HS_UAMALIASNAME=chilli
HS_UAMFORMAT=URL
HS_UAMHOMEPAGE=URL
HS_ANYIP=on # Allow any IP address on subscriber LAN
HS_MODE=hotspot
HS_TYPE=chillispot
HS_WWWDIR=/etc/chilli/www
HS_WWWBIN=/etc/chilli/wwwsh
HS_PROVIDER=Coova
HS_PROVIDER_LINK=URL
HS_LOC_NAME=“My HotSpot” # WISPr Location Name and used in portal
