Is it possible to enable 802.11r fast roaming on the Marble B-3000?
When I go int he luci interface for the Marble there is no option for WLAN roaming, like I see on the Flint 2. Does the marble support 802.11r, and if so can it be enabled manually in /etc/config/wireless?
Thanks
Marble B3000 does not support the WLAN roaming, so 802.11r cannot enable this function on Luci or SSH.
Thank you for the information.
