The Specs are not that bad and for a only small not professional exoerience maybe enough? is it possible ? complicated ? Had someone tried it ? i only want to save my pictures , sync contact and need a cloud drive via nextcloud.
Thanks for your help
It is possible to run php based web application on the router. But I didn't try nextcloud on the router though.
Once a while ago, we tried to use NextCloud for our file shares. But eventually it is a disaster. Files just don't sync correctly. Maybe it is improved now. I use dropbox and never have a problem.
is it a web based script ? No i dont want to spend money for online cloud services. 4TB extern HDD for pictures and data . And how can i Install it ? is there a source to add ?
other guys here who tried it ?
I had used this but in a docker container.
But docker does require atleast 1gb space, and you may have to fiddle around for the /opt partition.
I don't use docker anymore on the Flint 2, because everytime i had to update the firmware I needed to reinstall the containers and docker, though for data or config you could make a bind mount to your hdd, but when usb is involved I would personally stay away for wifi problems, or accept use usb 2.0 speeds.
To me using a nuc with bind mounts was a much better solution than using docker on the router.
yeah but i have to use the Standard Router as modem - the Flint 2 Router and "then" a Homeserver / Nas too .. a IPTV Box etc - to much for me . I m saving one or two times in a week data - thats it . Without data - its no update problem ?
Some ideas here
https://openwrt.org/docs/guide-user/services/nas/owncloud
Might be other programs depending on what you need it to do.
https://openwrt.org/docs/guide-user/services/nas/start
Some of the choices are way more than simple click and go.
Firmware update may cause issues.
