Is it possible to limit battery percentage charging? I need to limit it by 85% to prolong battery life
It would probably help people answer your question if you let them know which device you are asking about.
This would generally be handled by the device if you are talking about tethered devices. For instance, I limit an android tablet to 85% as it is plugged in all the time (not into a router, but similar thought). If you are talking about one of the battery-enabled routers, the charger in the device should be managing this for you and may have a setting. Most monitor the batteries and will not overcharge lithium like the older battery technologies. IME, the batteries in these types of devices generally outlast my patience with them and the desire to upgrade anyway.
