Alphax
Is it possible to make router accessible via .lan domain?
I want to make it accessible via adm.lan
. It is easier to type this than IP.
Also… Is there any way to force redirect HTTP to HTTPS on 4.3 firmware as temporary measures until this will be added in 4.6?
admon
2
It's only some DNS thing, so if you add adm.lan
to your DNS or AdGuard Home, it will work.
This already exists in the submenu "Security"
slesar
4
Yes, in Luci hostname manual and DHCP
Alphax
5
Can I use it as alias? I mean don’t remove console.gl-inet.com
bruce
7
Both can. Say to change or add, also delete.
