In Wireless section of Luci I've create an access point using WPA3 EAP. I've configured Free Radius to use EAP-TLS. Its working. I'm using OpenWrt 21.02-SNAPSHOT.
From /etc/config/wireless:
config wifi-iface 'guest5g'
option device 'radio0'
option mode 'ap'
option ifname 'wlan1-1'
option guest '1'
option wds '1'
option macfilter 'allow'
option wpa_disable_eapol_key_retries '1'
option ssid 'MYAP'
option network 'lan'
option encryption 'wpa3+ccmp'
option auth_server '127.0.0.1'
option auth_secret 'MYSECRET'
option macaddr '00:00:00:00:00:00'
macOS says I'm connected to WPA3 Enterprise. In the Luci Wireless Overview it says the AP is Encryption: WPA2 802.1X (CCMP). When I edit the AP it says WPA3-EAP Strong Security. The cipher is Force CCMP (AES). Debian says its WPA2 Enterprise.
Why am I seeing different versions being reported? Have I misconfigured something?
Can you please let me know how I can check the configuration is secure?
