I don't see the function "allow custom DNS to overrite VPN DNS" on my model of travel router. Is any other solution to set up ISP?
Thanks' for advise!
Bea
If possible, please upgrade the beta firmware v4.7.2 on the SFT1200, it will add this feature.
the upgrade was failing. I\ve tried 5 times. After completing download 100 % GLiNet router is disconnecting.
What current firmware version of the SFT1200?
That is strange. ![]()
Version
4.7.2, where I will find this function - ovverrite IP?
Yes, v4.7.2 firmware added it.
Did the upgrade itself fail, or does the internet connection fail after the upgrade?
I had a similar problem , where the 4.3.21 from where I started had a stable connection, it totally failed after the upgrade to 4.7.2
After deleting the known networks setup, and selecting another SSID it worked.
So far the problem was that the SSID I used was using the 5 GHz DFS channels (all above the 36,40,44,48 is DFS in Europe) . 4.3.21 will connect to those, 4.7.2 does not.
Later there was unstability seen. The wifi signal was very unstable on both radio's. Setting them to LOW was the best, but still very unstable setting. No fix so far.
