Hi GL.iNet Team and Community,
I am a user of the Beryl 7 (GL-MT3600BE) Wi-Fi 7 pocket router. I’ve noticed that the new firmware version 4.11.0 has brought many exciting core features, especially the new SQM Cake queue (with Cake Autorate), Wi-Fi 7 driver optimizations, and native 802.1Q VLAN support.
I checked the official download center but couldn't locate a 4.11.x build under the Testing or Beta tabs for the MT3600BE yet.
Could you please let me know if there is an active 4.11 Testing/Snapshot firmware available for this model? If so, could you share the download link or let us know the rough timeline for when the MT3600BE will join the 4.11 upgrade cycle?
Thank you so much for your help and continuous support!
Best regards,
[HEIJIN]
Thanks for your interest! There is currently no v4.11 beta available for Beryl 7 (GL-MT3600BE).
Our current tentative plan is to release the beta in mid-to-late November, followed by the stable release around early January. These are estimated timeframes and may change depending on testing progress.
Hello
For this router GL-MT3600BE (Beryl 7)
My question is for the technicians.
Could you add an AUTO option under Network Acceleration in the next update? At the moment, it only has the Hardware Acceleration option.
In my case, setting it to AUTO makes the internet faster.
Would it also be possible for Wi-Fi
5 GHz and 4 GHz to support connecting older devices, as in previous GL.iNet versions such as the 3000AX
These older devices do connect via MLO, but it would be good to have the 5 GHz and 4 GHz option as well.
In my case, I like to know which band my devices are connected to.
Thank you
| 4.11.0 Beta1 Port forwarding does not work on this beta. Can't access from LAN |
Goodcloud can see it though
If I enter the local IP address as HTTPS, I can access the router. Forcing HTTPS does not
The available Network Acceleration modes depend on chipset support, so these options may remain unchanged in future firmware updates.
Beryl 7 should already allow you to configure separate 2.4 GHz and 5 GHz Wi-Fi networks with different names (SSIDs), without using MLO. You can configure each band under WIRELESS > Main Network. Please see our wireless setup guide.
What issue are you encountering when setting up or connecting your older devices to these separate networks?
We tested remote access through GoodCloud, and it worked on our side.
From your follow-up, direct HTTPS access works. Is the remaining issue that HTTP does not redirect to HTTPS, or that a forwarded service cannot be reached? Could you share a screenshot showing the error or behavior, with any sensitive details hidden?
HTTP does not redirect to HTTPS from my LAN which is the WAN of the router Port forwarding has not changed. It works fine with my BerylAX and worked before with the previous firmware on the Beryl 7. I also can access it through good cloud.
Regarding this router, GL-MT3600BE (Beryl 7, could you provide GL-MT3600BE**4.11.0 as soon as possible? The current version of OpenWrt is very outdated, and the system uses too much storage. When installing plugins myself, I can only install a few before running into memory limitations. **
Hello.
When I set the SSID for both 5 GHz and 2.4 GHz and try to connect two TV boxes from different brands, they keep trying to connect until the “Retry connection” message appears, but they never connect. I’ve tried several times, with no luck. I’ve tried different firmware versions, including yesterday’s latest beta, 4.11.1, released on 11/11/26, but still no luck.
I have another, newer TV box that does connect to this 3600BE router.
And all of them connect without any problems on both frequency bands with the GL.3000AX.
Thanks.
