I have several OpenVPN/WireGuard clients defined. I want to use an external service like HomeAssistant to connect/disconnect to one of those vpns. I’m assuming an http post or REST command can do this? Can you please point me in the right direction?
That’s never worked. And if I’m going to have to SSH in, I might as well just use curl.
As far as i can see /etc/init.d/wireguard st[art|op] is marked as solution.
Another try is the GL.iNet API: Loading...
https://dev.gl-inet.com/api/#api-OpenVPN-GetOvpnServerStart
https://dev.gl-inet.com/api/#api-Wireguard-PostWireguardServerStart
Answered you here Can’t execute a simple curl command? - #4 by WhiskerBiscuit
