Is it possible to somehow clean the log so its basically like new? Reading through days worth of entries is annoying. Doesn’t matter if not obviously. Thanks.
What is the device and firmware being used?
In LuCi you can change the size of the log in the system tab.
Flint AX1800 with 4.2.3
Try Restart or Stop/Start the log service in LuCI → System → Startup. I am not sure under Firmware 4, but logging was previously kept in memory that would be released when the service gets stopped.
