Hi all,
Is there a possibility to reset the Adguard plugin to the default values on flint2 with 4.7.7 stock firmware without resetting the entire device? I tested the solution offered in ADguard doesn't work after add several custom DNS lists. How to reset it pleasE? - #4 by TomKatt by completely removing the configuration file, but this resulted in having to go through the entire Adguard setup process.
I ended up blocking my laptop with too restrictive settings for DNS. Currently I'm using a statically assigned IP for the DNS resolver: as it's too old to get dhcp properly.
My current settings for DNS are
client - having set the DNS resolver to the default router IP
router:
DNS Rebinding Attack Protection - true
udhcpd - all defaults
Using DNS over TLS in the moment with cloudflare as work-around
Additional questions:
- is the default adguard plugin port 3000 accessible to unauthenticated users on the local lan?
- is the GLDDNS system now using https ( for versions 4.7.7 and above ) for dyndns or not?
