Is there VPN leaks when GL-XE3000 router switches from cellular to repeater, and vice versa?
I have this. GL-XE3000 / Puli AX - GL.iNet
I always have VPN turned on. And "block non VPN traffic" check box on. So everything "should" stay inside the VPN tunnel and not leak outside.
But Im wondering, when I take router from inside home to outside, router switches from repeater mode to cellular mode.
If I'm on a teams call, and router switches from repeater to cellular and vice versa, when the connection is reestablished, will there be a small VPN at that time? a small amount?
Or there are no VPN leaks and everything stays inside the tunnel during repeater/cellular switch overs?
I'd like to know the answer to this as well. I had those 2 exact settings turned on but may have had a leak with OpenVPN's DNS and got caught. Or it could have been just a small VPN leak like you said. Hopefully, admin or devs can chime in whether the router stays 100% inside the tunnel or not.
you got a leak and got caught by your employer? what did they say?
did your router switch between repeater and cellular alot? and thats where maybe the caught happened?
You can take a look at my thread here: MT1300 (Beryl) - OpenVPN Leak?
@Ralph1 looks like you had DNS leak yea? since you didn't configure that to be explicitly using VPNs DNS.
@elorimer thoughts?
@vpntravel thoughts?
That seems to be the conclusion but I'm still a bit confused why/how this could have happened when I had those 2 settings (your original post) selected. I, like many others, would assume this means everything stays inside the tunnel.
There should be a warning or settings somewhere about DNS needs to be set correctly as well in Beryl. Otherwise, VPN really isn't VPN if anyone know your real location by DNS.
did you ever do a test like this?
did the DNS servers show home country or the foreign country servers?
yea i did all the checks before trying. I made sure IP and DNS went through the tunnel.
with the two options selected, you were able to browse the internet just fine right?
I think DNS is only one element of the puzzle, and a problem could be not with the router, but instead the device you are using to connect to the router.
could it be because there is a small leak during when router first connects to internet and turns on VPN?
Read some of release notes. Several upgrades have addressed DNS leaks which leads me to believe those settings are not bulletproof. Also, your Beryl still on version 3 I think. Check text of all release notes, especially current ones.
bump
any staff can answer if we get VPN leaks during first time connect?
anyone?
