I am having an issue installing Haproxy on GL-B2200 / Velica. It seems an issue with package dependencies. is there any way around
root@GL-B2200:~# opkg install haproxy
Installing haproxy (1.5.16-01) to root…
Downloading http://download.gl-inet.com/releases/packages-3.x/ipq40xx/packages/haproxy_1.5.16-01_ipq806x.ipk
Installing libltdl (2.4-1) to root…
Downloading http://download.gl-inet.com/releases/packages-3.x/ipq40xx/base/libltdl_2.4-1_ipq806x.ipk
Configuring libltdl.
Configuring haproxy.
/usr/sbin/haproxy: can’t load library ‘libssl.so.1.0.0’
Now I can not remove the package to install haproxy-nossl even with
root@GL-B2200:~# opkg remove haproxy
Removing package haproxy from root…
cat: can’t open ‘/var/run/haproxy.pid’: No such file or directory
sh: you need to specify whom to kill
You can force removal of packages with failed prerm scripts with the option:
–force-remove
No packages removed.
Collected errors:
- pkg_run_script: package “haproxy” prerm script returned status 1.
- opkg_remove_pkg: not removing package “haproxy”, prerm script failed
root@GL-B2200:~# opkg remove haproxy --force-remove
Collected errors: - pkg_run_script: package “haproxy” prerm script returned status 1.
