Hi. I have a Flint 2 Home Router as my Wireguard VPN Server. I also have a Slate AX travel router. When I connect to my travel router as a wireguard client, I’m able to login using my work laptop, and everything runs fine except for my Microsoft Teams. Are there any setting adjustments I can make to get MS Teams working?
Could you let us know what firmware versions your routers are running?
Perhaps you could first try SSHing into the Slate AX and run the following command to see whether it fixes the issue for you:
