Issue with latest TOR FW for MT300N-v2
Dear GL.iNet team,
first of all thanks a lot for the great concept of an open, accessible, cheap and well documented product!
I have not been able to resolve an issue while trying to flash the openwrt-mt300n-v2-tor-3.105 onto my new MT300N-v2. After sucessfully flashing it shows me the normal interface for the non-Tor firmware and nothing Tor-specific.
When flashing to lede-mt300n-v2-tor-2.264 I can access the Domino- an luci-interface with the Tor symbol but can not get the MT300N-v2 to connect to another wifi or via LAN. Upgrading from there does not work, after reboot FW ist still 2.264.
I had to use Uboot several times in the process of flashing, tried both Tor-FW-versions this way.
As I am unexperienced with, I was also not able to build a new Tor-firmware from your instructions.
I use MacOS mainly, Chrome does a better job for this than firefox btw.
I wondered if the 3.105 FW just does not install properly and the former FW remains?
Can you help me with this, please?
Thanks a lot in advance,
neoander
Pls check there is Tor firmware for 3.105 as well.
https://dl.gl-inet.com/firmware/mt300n-v2/tor/
