Issue with openvpn connect on android phone
Hi everyone,
with this app I´m perfectly connecting using profile xxx.cg-dialup.net:443 (UDP) but when using a ddns profile like for example xxx.glddns.com:1194 it can´t connect.
Any help to solve this problem will be greatly appreciated
If you use the nslookup command, would the two domain get the same IP address?
Hi rain, I hven't used the nslookup command because I found an easy workaround to access my home windows 10 pc through a mango openvpn server behind a main router. On remote I'm using an android phone wirh an OpenVPN Connect app as a client together with the AndSMB app which access perfectly to my home PC.
I hope this will help other users.
