trying to use hide.me vpn
created an account on their site but configuring the router falls with this
get third part provider token fail [20001211]
i dont see anything in kernal or sys log that gives more information
any ideas?
any ideas?
I'm not sure if this helps but I was on 4.7.0 and I received "invalid token" when trying to use a Windscribe account, maybe it's related to the 4.7.0 firmware. I upgraded to 4.7.4 beta and it fixed my issue.
But also check that your username / password credentials are not different to your master login. Some providers have a username / password to login and a different one for the VPN configs...
You could also just use the custom option and manually import a config to see if that at least connects / works.
My device is running in 4.7.0 and facing the same issue while trying to login
Surfshark, anyone can support here?
I'm also running Surfshark with 4.7.4 also having this issue, any help?
