I have a GL-AR300M with the latest version of the firmware.
I am using it with OpenVPN to connect to a OpenVPN server and everything works fine except multicast (SSDP) traffic which, at the moment, is NOT routed to the tun0 interface and I don’t understand why.
The devices connected to the br-lan interface(s) do generate UDP SSDP multicast traffic using port 1900 and destination address 239.255.255.250.
If I dump the traffic at the br-lan interface with tcpdump I do see this traffic but if I dump the traffic at the tun0 interface I don’t see any of this traffic anymore.
I have played with iptables to make sure that this type of traffic doesn’t get dropped and I have added a static routing rule as well but with no luck.
I have also installed scmroute to subscribe the br-lan to a multicast group but I still can’t see any multicast traffic being routed from br-lan to tun0.
Do you have any suggestions on how I can achieve that? As I said I would like to somehow add a routing/forwarding policy to route all the SSDP traffic generated by a specific IP and coming from the br-lan interface to the tun0 interface.
I already don’t understand why it is not happening after all the configurations I made but I’m clearly missing something.
Thanks in advance for your help.
Sergio
