Issues with Residential WireGuard VPN Connection
Client Setup:
  • Device: Slate AX (GL-AXT1800)- Connected to M.E ISP router in repeater mode
Server Setup:
  • Device: GL-SFT1200 Opal
  • Internet Service: AT&T Fiber Optic, 1 Gig
Problem Description:
I have been using this Residential WireGuard VPN setup successfully for the past year. However, a few weeks ago, I started experiencing issues with connecting to my server in the US. We have confirmed that the server is not the problem.
Symptoms:
  • The client shows as connected initially it indicating upload traffic but no download traffic.
  • Eventually, the connection fails shortly after about 15-20 seconds displaying a “client starting” message, followed by a complete loss of any connection.
  • Rebooting the ISP router multiple times is required before a stable connection is re-established. Can take many hours before it would work.
I’m unsure what could be causing these connection issues. Any guidance or suggestions would be greatly appreciated. I am ready to provide additional information as needed and will update this post with the most recent log file soon.
I would assume that this one is the problem.
Do you know if the country tries to execute censorship and/or blocks VPN?
I almost want to agree but I have another client router that connects to it as well
Please upload the log files so someone can look into it.
Sun Dec 31 18:38:04 2023 daemon.notice netifd: Interface ‘wgclient’ is setting up now
Sun Dec 31 18:38:04 2023 daemon.notice netifd: Network device ‘wgclient’ link is up
Sun Dec 31 18:38:04 2023 daemon.notice netifd: Interface ‘wgclient’ is now up
Sun Dec 31 18:38:04 2023 user.notice firewall: Reloading firewall due to ifup of wgclient (wgclient)
Sun Dec 31 18:38:08 2023 user.notice wgclient-up: env value:T_J_V_ifname=string J_V_address_external=1 USER=root ifname=wgclient ACTION=KEYPAIR-CREATED N_J_V_address_external=address-external SHLVL=3 J_V_keep=1 HOME=/ HOTPLUG_TYPE=wireguard T_J_V_interface=string J_V_ifname=wgclient T_J_V_link_up=boolean LOGNAME=root DEVICENAME= T_J_V_action=int TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin CONFIG_LIST_STATE= J_V_interface=wgclient K_J_V= action ifname link_up address_external keep interface J_V_link_up=1 J_V_action=0 T_J_V_address_external=boolean N_J_V_link_up=link-up T_J_V_keep=boolean PWD=/ JSON_CUR=J_V CONFIG_SECTIONS=global AzireVPN Mullvad FromApp group_5249 group_4568 group_7535 group_5072 peer_6640 CONFIG_cfg030f15_ports=
Sun Dec 31 18:39:09 2023 daemon.notice netifd: wgclient (11902): * Zone ‘guest’
Sun Dec 31 18:39:09 2023 daemon.notice netifd: wgclient (11902): * Zone ‘wgclient’
Sun Dec 31 18:39:09 2023 daemon.notice netifd: wgclient (11902): * Set tcp_ecn to off
Sun Dec 31 18:39:09 2023 daemon.notice netifd: wgclient (11902): * Set tcp_syncookies to on
Sun Dec 31 18:39:09 2023 daemon.notice netifd: wgclient (11902): * Set tcp_window_scaling to on
Sun Dec 31 18:39:09 2023 daemon.notice netifd: wgclient (11902): * Running script ‘/etc/firewall.nat6’
Sun Dec 31 18:39:09 2023 daemon.notice netifd: wgclient (11902): * Running script ‘/etc/firewall.swap_wan_in_conn_mark.sh’
Sun Dec 31 18:39:09 2023 daemon.notice netifd: wgclient (11902): * Running script ‘/var/etc/gls2s.include’
Sun Dec 31 18:39:09 2023 daemon.notice netifd: wgclient (11902): ! Skipping due to path error: No such file or directory
Sun Dec 31 18:39:09 2023 daemon.notice netifd: wgclient (11902): * Running script ‘/usr/bin/gl_block.sh’
Sun Dec 31 18:39:09 2023 daemon.notice netifd: wgclient (11902): * Running script ‘/etc/firewall.vpn_server_policy.sh’
Sun Dec 31 18:39:09 2023 daemon.notice netifd: wgclient (11902): uci: Entry not found
Sun Dec 31 18:39:09 2023 daemon.notice netifd: Network device ‘wgclient’ link is down
Sun Dec 31 18:39:10 2023 daemon.notice netifd: wgclient (11902): sh: 1: unknown operand
Sun Dec 31 18:39:10 2023 daemon.notice netifd: wgclient (11902): udhcpc: started, v1.33.2
Sun Dec 31 18:39:10 2023 daemon.notice netifd: wgclient (11902): udhcpc: sending discover
Sun Dec 31 18:39:13 2023 daemon.notice netifd: wgclient (11902): udhcpc: no lease, failing
Sun Dec 31 18:39:13 2023 daemon.notice netifd: Interface ‘wgclient’ is now down
Sun Dec 31 18:39:13 2023 daemon.notice netifd: Interface ‘wgclient’ is setting up now
Sun Dec 31 18:39:13 2023 user.notice firewall: Reloading firewall due to ifdown of wgclient ()
Can you please tell where in the Middle East you are located? I am also experiencing the same thing but with IPsec.
please remove wireguard client listen port if there’s one, also try to restart the SFT1200 wireguard server.
