Issues with Tailscale remote lan access
GL-MT3000... v4.6.2
I have been using tailscale from my phone to access various ips on my home network via remote access lan for some time. Now suddenly, having made no changes I can no longer access any of them. I can access the router itself remotely using its tailscale ip but nothing else. I don't have the necessary network skills to investigate further. Please help.
Re-check the router to make sure you have "allow remote access LAN" option turned on and check the Tailscale admin console to make sure "subnet routes" is on and have correct subnet configured.
Read the logs on router and Tailscale sides to see any possible clues.
(Since you still can remote access to your router, that should not be the key expired issue)
Hi, I have already checked the router settings and Tailscale routes. All seems fine.
The router logs don't mean much to me but after a failed connect it reads:
Fri Jul 19 19:56:00 2024 kern.warn kernel: [37155.190322] 7981@C08L2,ap_peer_disassoc_action() 3645: ASSOC - 1 receive DIS-ASSOC request
Fri Jul 19 19:56:00 2024 kern.warn kernel: [37155.198696] 7981@C01L2,wifi_sys_disconn_act() 1002: wdev_idx=0
Fri Jul 19 19:56:00 2024 kern.notice kernel: [37155.205559] 7981@C08L3,hw_ctrl_flow_v2_disconnt_act() 172: wdev_idx=0
Fri Jul 19 19:56:00 2024 kern.warn kernel: [37155.212576] 7981@C13L2,MacTableDeleteEntry() 1938: Del Sta:10:ae:60:1c:af:35
Fri Jul 19 19:56:00 2024 kern.notice kernel: [37155.220031] 7981@C08L3,ap_peer_deauth_action() 437: AUTH - receive DE-AUTH(seq-264) from 10:ae:60:1c:af:35, reason=3
I disabled tailscale on router, deleted entry on tailscale itself and re-enabled everything. All good now but curious as to why it all stopped working since I had made no changes.
