Issues with X300BRC4, "SIM card not registered"
I have a “Collie” device, supposedly 4G, but I am having issues. It has worked so far with one carrier here in Iceland, but I wanted to switch to another carrier that no longer has 2G/3G and I get the “SIM card not registered” error.
The first carrier still works, but I get 3G speeds of less than 8 mpbs and they are also soon shutting down the old 2g/3g networks, so I fear I will have issues at that time.
I wonder what I can do to make it work with the new carrier? Shouldn´t the device not work with any 4G network?
I have played around with the APN, the Network settings (3G, QMI, QMC) but nothing helps.
Hoping to get assistance.
Hello, the Collie does support 4G. You can try the following troubleshooting steps first to see if it helps:
  1. Check the sim Card and the antenna: make sure the sim card is activated and the 4G antenna is properly connected
  2. After inserting the new sim card, reboot the router. Try connecting it by cellular Auto Setup
  3. If Auto Setup doesn't work, stop the cellular connection. Manually fill in APN and retry
If issue persists, export the system log and the modem-debug info (this can be exported from Cellular section ->Modem Management page). You can PM me the relevant info or send to support@gl-inet.com to check.
Thanks for the suggestions Cathy. I have actually tried all of that, in addition I have tried various AT commands to force certain conditions.
Let’s set this up:
Carrier 1: Siminn - Works every time, regardless of settings that I have or change, i.e. works on their own APN, but also the APN of carrier 2. Speeds are “slow” ~8 mpbs (perhaps to be expected from the Collie?). This carrier still has 2/3G.
Carrier 2: Nova - Has never worked, despite setting APN, PAP, AUTH or any other setting. This carrier no longer has 2/3G. This carrier also piggybacks on another carriers towers.
The logs have shown that when I put in the Nova SIM card, the Collie will not work well, even reboot the modem:
Summary
Fri Jan 2 00:49:35 2026 daemon.notice netifd: modem_1_1 (31464): cat: can't open '/proc/gl-hw-info/sim': No such file or directory
Fri Jan 2 00:49:36 2026 daemon.info gl-cloud[6404]: (gl-cloud:230) fetch server from: https://gslb-eu.goodcloud.xyz/gslb/getbucket?deviceType=1&mac=9483c45a7cab&sn=89a49ba711cc5f46&ddns=rza7cab&timestamp=1767314976&sign=419e3b2c35038da7d8e0536e2b30c4c6
Fri Jan 2 00:49:36 2026 daemon.err gl-cloud[6404]: (gl-cloud:234) fetch server fail: resolve "gslb-eu.goodcloud.xyz" fail: refused
Fri Jan 2 00:49:36 2026 daemon.err gl-cloud[6404]: (gl-cloud:495) reconnect mqtt in 160s...
Fri Jan 2 00:49:36 2026 daemon.notice netifd: modem_1_1 (31464): Waiting for SIM initialization
Fri Jan 2 00:49:36 2026 daemon.notice netifd: modem_1_1 (31464): Starting network modem_1_1
Fri Jan 2 00:49:37 2026 daemon.notice netifd: modem_1_1 (31464): Unable to connect IPv4
Fri Jan 2 00:49:37 2026 daemon.notice netifd: modem_1_1 (31913): Stopping network modem_1_1
Fri Jan 2 00:49:37 2026 daemon.notice netifd: modem_1_1 (31913): Command failed: ubus call network.interface notify_proto { "action": 0, "link-up": false, "keep": false, "interface": "modem_1_1" } (Permission denied)
Fri Jan 2 00:49:37 2026 daemon.notice netifd: Interface 'modem_1_1' is now down
Fri Jan 2 00:49:37 2026 daemon.notice netifd: Interface 'modem_1_1' is setting up now
Fri Jan 2 00:49:49 2026 daemon.notice netifd: modem_1_1 (31921): SIM not ready
Fri Jan 2 00:49:50 2026 daemon.notice netifd: modem_1_1 (31921):
Fri Jan 2 00:49:50 2026 daemon.notice netifd: modem_1_1 (31921): ERROR
Fri Jan 2 00:49:57 2026 daemon.notice netifd: modem_1_1 (31921):
Fri Jan 2 00:49:57 2026 daemon.notice netifd: modem_1_1 (31921): OK
Fri Jan 2 00:49:59 2026 daemon.notice netifd: modem_1_1 (31921): Failed to parse message data
Fri Jan 2 00:50:01 2026 daemon.notice netifd: modem_1_1 (32358): Stopping network modem_1_1
Fri Jan 2 00:50:01 2026 daemon.notice netifd: modem_1_1 (32358): Command failed: ubus call network.interface notify_proto { "action": 0, "link-up": false, "keep": false, "interface": "modem_1_1" } (Permission denied)
Fri Jan 2 00:50:01 2026 daemon.notice netifd: Interface 'modem_1_1' is now down
Fri Jan 2 00:50:03 2026 user.notice firewall: Reloading firewall due to ifdown of modem_1_1 ()
Fri Jan 2 00:50:03 2026 daemon.notice netifd: Interface 'modem_1_1' is setting up now
Fri Jan 2 00:50:09 2026 user.notice kmwan: config json str={ "op": 3, "data": { "cells": [ "modem_1_1" ] } }
Fri Jan 2 00:50:20 2026 daemon.notice netifd: modem_1_1 (32436): SIM not ready
Fri Jan 2 00:50:20 2026 daemon.notice netifd: modem_1_1 (32436): ERROR
Fri Jan 2 00:50:22 2026 daemon.notice netifd: modem_1_1 (32436):
Fri Jan 2 00:50:22 2026 daemon.notice netifd: modem_1_1 (32436): ERROR
Fri Jan 2 00:50:27 2026 daemon.notice netifd: modem_1_1 (32436): Failed to parse message data
Fri Jan 2 00:50:28 2026 daemon.notice netifd: modem_1_1 (32436):
Fri Jan 2 00:50:28 2026 daemon.notice netifd: modem_1_1 (32436): ERROR
Fri Jan 2 00:50:30 2026 daemon.notice netifd: modem_1_1 (32436):
Fri Jan 2 00:50:30 2026 daemon.notice netifd: modem_1_1 (32436): ERROR
Fri Jan 2 00:50:33 2026 daemon.notice netifd: modem_1_1 (32436): cat: can't open '/proc/gl-hw-info/sim': No such file or directory
Fri Jan 2 00:50:34 2026 daemon.notice netifd: modem_1_1 (32436): Waiting for SIM initialization
Fri Jan 2 00:50:34 2026 daemon.notice netifd: modem_1_1 (32436): Starting network modem_1_1
Fri Jan 2 00:50:35 2026 daemon.notice netifd: modem_1_1 (32436): Unable to connect IPv4
Fri Jan 2 00:50:35 2026 daemon.notice netifd: modem_1_1 (531): Stopping network modem_1_1
Fri Jan 2 00:50:35 2026 daemon.notice netifd: modem_1_1 (531): Command failed: ubus call network.interface notify_proto { "action": 0, "link-up": false, "keep": false, "interface": "modem_1_1" } (Permission denied)
Fri Jan 2 00:50:35 2026 daemon.notice netifd: Interface 'modem_1_1' is now down
Fri Jan 2 00:50:35 2026 daemon.notice netifd: Interface 'modem_1_1' is setting up now
Fri Jan 2 00:50:45 2026 daemon.notice netifd: modem_1_1 (542):
Fri Jan 2 00:50:45 2026 daemon.notice netifd: modem_1_1 (542): ERROR
Fri Jan 2 00:50:46 2026 daemon.notice netifd: modem_1_1 (542):
Fri Jan 2 00:50:46 2026 daemon.notice netifd: modem_1_1 (542): ERROR
Fri Jan 2 00:50:47 2026 daemon.notice netifd: modem_1_1 (542):
Fri Jan 2 00:50:47 2026 daemon.notice netifd: modem_1_1 (542): OK
Fri Jan 2 00:50:50 2026 daemon.notice netifd: modem_1_1 (542): Failed to parse message data
Fri Jan 2 00:50:51 2026 daemon.notice netifd: modem_1_1 (542):
Fri Jan 2 00:50:51 2026 daemon.notice netifd: modem_1_1 (542): ERROR
Fri Jan 2 00:50:54 2026 daemon.notice netifd: modem_1_1 (542):
Fri Jan 2 00:50:54 2026 daemon.notice netifd: modem_1_1 (542): ERROR
Fri Jan 2 00:50:57 2026 daemon.notice netifd: modem_1_1 (542): cat: can't open '/proc/gl-hw-info/sim': No such file or directory
Fri Jan 2 00:50:58 2026 daemon.notice netifd: modem_1_1 (542): Waiting for SIM initialization
Fri Jan 2 00:50:58 2026 daemon.notice netifd: modem_1_1 (542): Starting network modem_1_1
Fri Jan 2 00:50:58 2026 daemon.notice netifd: modem_1_1 (542): Unable to connect IPv4
Fri Jan 2 00:50:58 2026 daemon.notice netifd: modem_1_1 (987): Stopping network modem_1_1
Fri Jan 2 00:50:59 2026 daemon.notice netifd: modem_1_1 (987): Command failed: ubus call network.interface notify_proto { "action": 0, "link-up": false, "keep": false, "interface": "modem_1_1" } (Permission denied)
Fri Jan 2 00:50:59 2026 daemon.notice netifd: Interface 'modem_1_1' is now down
Fri Jan 2 00:50:59 2026 daemon.notice netifd: Interface 'modem_1_1' is setting up now
Any thoughts on this new info?
Has this X300B been updated to v4? If yes, could you go to INTERNET ->Cellular ->Modem Management, export the modem debug info and send to us for further investigation?
Yes, I am on the latest version. I am currently at work, as soon as I have the chance I will provide the logs.
