Iam using flint router as a vpn server (wiregard) and a beryl ax as client everything is working fine except when i try to connect to avanti secure client through this configuration. do you have any idea if i have to change some settings ?
iam using DDNS for my configuration
thank you guys
I can change it but I think it’s not the issue I’ve seen that ivani recommends to set mtu to 1500 I’ve change it on the gl server and client the problem maybe related to the fact that iam using WireGuard to connect with ivanti who use ssl maybe someone had the same issue
