I’m unable to access my GL-Mt300N-V2 from goodcloud via web or ssh. Currently I have the WAN interface hooked up to a Huawei LTE modem and the LAN interface is connected to the lan port of my ASUS router.
It’s setup this way as a backup means to administer the ASUS router if the site to site vpn would fail to start.
I can currently access the cli via SSH from the ASUS router but nothing else. Upon logging in via ssh I get this message:
“Your JFFS2-partition seems full and overlayfs is mounted read-only.
Please try to remove files from /overlay/upper/… and reboot!”
df -h output
root@GL-MT300N-V2:~# df -h
Filesystem Size Used Available Use% Mounted on
/dev/root 11.8M 11.8M 0 100% /rom
tmpfs 59.6M 364.0K 59.2M 1% /tmp
/dev/mtdblock6 1.6M 1.5M 72.0K 96% /overlay
overlayfs:/overlay 1.6M 1.5M 72.0K 96% /
tmpfs 512.0K 0 512.0K 0% /dev
/dev/sda1 57.4G 24.0K 54.4G 0% /mnt/extroot
cat /etc/config/fstab
config global
option anon_swap ‘0’
option anon_mount ‘0’
option auto_swap ‘1’
option auto_mount ‘1’
option delay_root ‘5’
option check_fs ‘0’
config mount ‘rwm’
option device ‘/dev/mtdblock6’
option target ‘/rwm’
option enabled ‘1’
My linux knowledge is very limited and since this is a remote node, I’m not sure how to fix this.
