I connect to Internet over wifi from the GL-AXT1800.
I run 2 wifi it “could” connect to.
JOLLYBOYZ - This is the house network running on 5G and 2.4GHz, on a Cisco RV260W. Channel 58 and 11.
JOLLYBOYZ_INT - This is solely to connect GL-INET router to wifi, runs on a Cisco Meraki G on a different channel to stop the 2 SSIDs from slowing each other down. This runs only on 5G. Channel 44.
However when I scan to Join the network, I see:
JOLLYBOYZ 2.4GHz
JOLLYBOYZ_INT Mixed.
Seemed to have swapped these around.
Edit: The device connects on channel 44, and shows 5G in the Internet page. It is only in scanning it seems incorrect.
Simon
When I try to ip link set sta0 up - I get a Resource Busy error.
ip link show sta0 gives:
19: sta0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 4096
link/ether aa:17:62:0b:89:f4 brd ff:ff:ff:ff:ff:ff
I alredy have wla-sta0 for my wwan interface, so I can scan on that?
I think radio only allows one sta connection.
10: wlan-sta0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP mode DORMANT group default qlen 4096
link/ether 94:83:c4:19:93:27 brd ff:ff:ff:ff:ff:ff
I have been scanning through the Luci and the GL-INET interface.
In LuCI Radio 0 (which I believe wlan-sta0) can scan. Radio 1 cannot scan in either, I presume the GL-Inet does something funky to get its scan list.
