i have a verizon actiontec coax fios router
Digital Nomad VPN Setup | Tech Relay was reading that to connect my gl-inet routers I have to connect the router directly to my verizon box using ethernet (which ican’t do , old home fishing wires etc ). So Im wondering how could I do this, most easily, using my existing setup. Is there a way to connect my gl-inet router to my existing actiontec verizon fios router, and then take my second travel router and connect to it?
In other rooms in my home I have a coax cable in the wall which I use a coax ->ethernet adapter with ->local router in AP mode. That’s how the internet in my home is setup
Cant i just connect this to my main router, by ethernet, put it in AP mode and be good to go? Edit: tried this and no wireguard features which is what I need
Some more questions
- Can’t do the wifi repeater because I have a !@#$ character(s) in my wifi password, noway to allow these characters?
- what happens to the setting in my travel router ( a second router I bought) if I unplug it to travel. Do I risk losing all its settings, is there away to locally backup the settings on an sd card in the sd card slot?
It would be super simple if I could somehow use wireguard/tailscale in ap mode…but tihs doesn’t seem possible?
