So I'm wondering. Obviously the firmware runs on openwrt and you guys released new firmware with bug fixes, adguard fixes, firewall rules for the VPN routing etc. When you are applying these fixes are these done at restricted level, by that I mean you are not modifying what Luci considered as settings? Could the fixes be in certain config files and potentially be overwritten by a older file from a backup archive for example.
The reason I ask is because I use SQM, adguard, upnp, ddns and it's easy just to restore my config that I make from within Luci after I upgrade, my concern is that when I restore I might inadvertently be restoring a file that you guys have edited?
Does the "keep settings" inside the GUI actually just run the backup / restore of Luci or is it different?
I know some upgrades say don't enable keep settings but it's a bit of a pain having to setup things again from scratch each time there's an update
So to sum up. Are the "keep settings" really just that, keeping the settings or are they keeping some files that could have been fixed in the newer firmware?
