Key sequence to toggle in and out of full screen
Can a client side key-sequence be configured to do what clicking the “Collapse Toolbar” and “Fullscreen” buttons do in the app, or can a key config be set to basically switch out of the KVM app from a maximized view and minimize it for a moment? I often need to switch between the system I’m on and the remote system and its like 3 mouse clicks to do it. Thank you!
Thanks for your usecase,the desktop app definitely need more customizable features due to its capabilities is different from the web.I will add your requests to our roadmap.
And regarding your second point, maybe right now you can try setting up a system shortcut to achieve it. i used MacOS and i set a specific shortcut to switch my Windows view in my daily use.
