OK, Everything was fine. Now only the keyboard works and the mouse doesn’t. This is for the Comet POE. I’ve changed cables, ports…maybe I’ll try a wired mouse? No idea what to screw with next.
What's your firmware version? 1.10?
Yep, Current Version: V1.10.1 release2
https://drive.google.com/file/d/1mARiwUBNjTcxX-VxUP1zASDWwrCiazV-/view?usp=drive_link Try this firmware to see if it can solve the problem
Sent request for access…Thank you! I’ll let you know if it worked when I’m given access to download it.
I fixed it. It said to change a number of things under the mouse settings, but they were of no help. In fact, changing the mouse from absolute to relative made the cursor vanish. It looks like under settings, changing to Customize and switching from GLKVM default to Logitech seemed to work. Now, both the keyboard and the mouse work.
I didn't anticipate that switching between absolute and relative mouse modes would cause this issue. Kudos to you for figuring out the solution independently—good job! I have also granted access to the firmware link, which may help.
