Kill Switch + LAN Access Feature
Hello, I have:
GL.iNet GL-MT2500
Kernel Version: 5.4.211
I have saw the Kill Switch + LAN Access post discussing the same issue I am experiencing. When I enable "Block Non-VPN Traffic," I am no longer able to access anything on my LAN. Essentially, I need to use a VPN at all times while still being able to access my LAN devices.
Is it possible to implement a feature that uses a VPN with a kill switch alongside a LAN?
The VPN, if not disabled, will have kill switch on it already.
So just don't use "Blocck Non-VPN Traffic" and it is OK.
Yes, but i want to block Non-VPN traffic and be able to access to my LAN.
That does not make sense.
How does your network look like?
This is my setup:
this setup works, when kill switch is not enabled.
But, when enabled it stops working.
Google wifi main provides internet to the gl.inet.
lan1 -> 192.168.8.0/24
lan2 -> 192.168.86.0/24
I have the same issue.
@alzhao Hey any update on this?
I am not sure what I should do. Seems this will cause security issues and leaks.
Will it be problem if you allow extra button or option to whitelist 192.168.0.0/16?
It is a problem since your needs are pretty custom. There are uplink networks using private IP space - in that case it would leak data.
Can you suggest a workaround I can implement my side?
