Does anyone know which Gl-inet device the Koalasafe KS-150N is based on?
Koalasafe have shutdown and pushed out Open-wrt to the devices, but only if they were in use in February, which mine wasn’t.
Whatever firmware it was gives a wifi name with Gi at the start, so I’m confident it was a Gl-inet device.
Tried the Ar-150 open wrt firmware, which installs, but then won’t detect the WAN port.
Seems to be based on a AR9330 chip (though maybe that’s my reading of the logs)
What makes you think that out of interest?
That’s the firmware I went with…but it’s not working properly.
More notes here;
"I’ve actually been playing around with a Koalasafe and trying to work out which firmware’s might work.
So, for starters, you can reset one and gain access (at least for the model I have, which is an KS-150N), by following Gl-inets’ instructions here;
I followed the instructions for the Gl-inet GL-AR150 (reasoning that the model numbering and the fact they look the same meant the Koalasafe was the same or similar hardware) and installed the Open-wrt firmware from here;
I’ve played around aa fair bit now - it’s definately having issues.
Seems to think there are 3 ports; 2 lan and one wan.
It connects the lan ok, but does not detect the wan.
I tried the firmware off the open-wrt page rather than the gl.inet. Same thing.
The annoygin thing is we know it works, as Koala safe released an open-wrt firmware. It would be infuriating if it had to be custom.
